i.MX8 M MINI Ethernet MAC
sameer_pitre
We want to use 10/100 Base-T Ethernet MII interface in our design. Following is the pin mapping as per i.MX8 M MINI datasheet.
We need the exact pin interface for MII mode.
Thanks and regards,
Sameer
gusarambula
Hello Sameer Pitre,
I confirmed that the i.MX8MM supports only RMII mode at 1.8V/3.3V and RGMII mode at 1.8V/2.5V. The MII configuration is not supported by the i.MX8M Mini. The next release of the documentation should fix any mention of MII mode.
My apologies for the inconvenience.
sameer_pitre
Hello Gusarambula,
Thanks for your reply. NXP need to correct the i.MX8MM Reference manual which has mention about MII support.(pg no.3691) Pl. refer below snapshot from the manual
Thanks and regards,
Sameer
gusarambula
Hello Sameer Pitre,
Thank you for pointing out this error. The next release of the documentation should fix any mention of MII mode.
