When I use i.MX8 ISI scaling camera frame,1280X720->640X480,ISI driver run this function:mxc_isi_channel_set_scaling()
get picture like this:
It seems crop the image not scale,does ISI have scale ablity?
I have replied to you in your another topic, let's just focus on one topic since they are the same questions.
I have already reply to your another topic, because this unit test doesn't support raw data directly
I make unit test program support RAW data in this case,ISI support downscaling RAW data ot not?
Is there someone can help?
I have already send the unit test source to you in your another similar topic, you can refer to that
Yes, I use that unit_test application do this test,for detail capture again
With Raw 12bit output camera it is not scale,but YUV camera can scaling:
Why about it?
