i.MX8: How to do encryption fot rootfs partition
2,312 次查看
kinjalGediya
I am using imx8mq for development purpose and I am trying to do rootfs encryption. I have followed documents which are suggested by NXP. Below are the documents which i have followed.
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
https://www.nxp.com/docs/en/application-note/AN12714.pdf
I have followed the steps and I have successfully encrypt the folder using commands which are given in document https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf.
I want to do a encrypt particular one rootfs partition but I haven't find any documents or information.
Can you help me for encrypt the particular partition in rootfs?
Thanks in advance
标记 (1)
3 回复数
2,280 次查看
b36401
I answered you via email.
2,265 次查看
kinjalGediya
Hi Victor,
Thanks for sharing the document.
I have a query on the document while I follow the steps which are given in the document, I am stuck at a step 2 which is given in section 3.5.2(Compile Cryptsetup). It looks like the command is incomplete and because of that I am getting the following error.
Can you please guide me for the same?
2,253 次查看
b36401
It seems your system lacks of popt (that provides libpopt libraries to parse command-line options).
So you need to install this package.
