1. Is NVCC_DRAM2P5 an input or output pin?
2. What is its role and how to use this pin?
3. Is it must connected with VDD_HIGH_CAP?
Solved! Go to Solution.
NVCC_DRAM2P5 is one of DDR I/O supply inputs (of 2.5V, look at the Datasheet).
It powers the pre-drivers of the DDR IO pins and can be powered by VDD_HIGH_CAP.
Yuri.
Yuri.
