[i.MX6ULL] Fuses: Differences between GPx and SW_GPx
1,032 次查看
ceggers
Contributor V
IMX6ULLRM.pdf, page 227ff, table 5-9 mentions some fuses which are available for application use. Is there any difference between fuses like GP1, GP2, ... and fuses named SW_GP? I would like to use one of this fuse registers in order to store an encrypted key.
标签 (1)
标记 (2)
1 回复
967 次查看
AldoG
The main difference between this two is the number of fuses each have, each GPx is 32 long while the SW_GP is 160.
Hope this helps
Aldo.
