i.MX6ULL EVK design questions
Search instead for
m_c
Senior Contributor I
In the page 10 of SPF-29364_A1.pdf, There is an MOSFET Q707 and gate pin connected with signal named DISCHG_EN.
1. What is function of Q707?
2. Can customer remove Q707 on their board?
3. Any side effect if remove Q707?
4. What is function of signal DISCHG_EN?
Yuri
   The discharge may be useful, when system reset is implemented as full power off and
then - on (in order to decrease discharge time).
Yuri.
Yuri
Yuri.
mrudangshelat1
Senior Contributor II
Hi M.C
Q707 and DISCHG_EN signal is used to discharge the SOC voltage when power is turned off.
You can remove it if you do not want to use it.
Mrudang
