i.MX6ULL Clock out signal for AFE4490?!
theevanvenugopa
Hey Team NXP!
I would like to provide clock pulse of 8MHz for one of my peripherals(AFE4490). I assigned the function to the below pin(P17). Is that Okay?
Bio_TICFSL
Hi Theevan,
You need to configure to run 8Mhz, configuration is described in sect. Miscellaneous Register 1 (PMU_MISC1n)
field LVDS1_CLK_SEL, i.MX6UL Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6ULRM.pdf
theevanvenugopa
@bio_ticfsl, I would like to check whether the pin P17 can be used for providing external clock of 8MHz to the External Peripheral(AFE4490)
Thank you.#clock output #External peripheral Clock #custom hardware
