i.MX6UL Power Consumption Measurements
768 次查看
bkarwacki
I am performing power measurements on the i.MX 6UltraLite EVK and have been trying to repeat the tests documented in AN5170. I have a couple of questions:
1. Paragraph 6.2.3 System Idle Mode: system setup - how do I boot up the Linux image with "x11=false uart_from_osc" in cmdline?
2. Paragraph 6.3.4: Dhrystone on Cortex-A7 - I get "dry2 - command not found." Is this included in the distribution? I am running: Freescale i.MX Release Distro 4.1.15-2.0.0
Bill
0 回复数
