i.MX6UL Development board with PSDRAM attached to EIM
Search instead for
j_araya
Dear Community,
Is there any development board you can recommend, either from NXP or any third-party company with a PSDRAM or FPGA attached to the EIM port of the i.MX6 processor?
Kind regards,
Jose
b45499
You can realize the EIM connect to the FPGA yourself. You can see the RM
j_araya
Hi Rita,
Thanks for your answer. The EIM port multiplexing described in the tables you mention can actually be quickly done with the PINS-TOOL-IMX, right?
I wanted to avoid the overhead of designing a PCB just to try the PSRAM interface of the EIM port, but if there is no other option I'll need to proceed as you suggest.
Bests,
Jose
