Hello community,
i wanted to know, which kind of DDR3L Standard Speed Bin is used at the i.MX6UL.
The datasheet and as well the reference manual are saying only DDR3L-800.
But there are two different kind of Speed Bins: DDR3-800D (5-5-5) and DDR3-800E (6-6-6)
Solved! Go to Solution.
generally any devices of DDR3-800D and DDR3800E may be used
with i.MX6 UL, but corresponding timings should be configured properly.
Please use simplified tool below to configure i.MX6 UL memory controller.
Yuri
Yuri
