Hi all
Does i.MX6SL support NOR flash that is dual die device for Boot?
If yes, is there any concern ?
Ko-hey
Solved! Go to Solution.
Hi Ko-hey
could you provide part number ?
Hi Igor
Plan to use FM25M4SA(128Mb or 256Mb).
It is manufactured by Fildelix.
Ko-hey
Hi Ko-hey
unfortunately I could not succeed to obtain its datasheet.
In general if it has standard spi and 2,3-bytes addressing
it can be used with i.MX6SL, no matter how many dies it has.
Hi Igor
I have the datasheet.
But I could not provide you at open site.
If I open a service request, could you check it ?
Ko-hey
Hi Ko-hey
ok, I will check it.
Hi Igor
Here is my SR# 1-4156284175.
Please check it.
Ko-hey
