Hi All,
We are using i.MX6 Solo processor in project.
During thermal testing, we observed that our CPU is not able to boot at high temperature (Ta=65Degree) because i.MX6 internal temperature sensor is reading temperature that exceeds threshold point.
Does anybody know about accuracy of the CPU die temperature sensor?
Also the maximum tolerance of internal die temperature sensor and calibration of sensor.
Thanks in advance,
Bipin Bhatt
解決済! 解決策の投稿を見る。
Hi Bipin
accuracy (variation of readings) is ~10deg (+/-10deg).
Hi Bipin
Hello Igor,
Thanks for your reply.
Does freescale documentation specify the accuracy of sensor anywhere?
Where did you find the above information?
Bipin
Hi Bipin
this is internal info.
OK.
Thank you.
Thanks & Regards,
Bipinchandra Bhatt
