i.MX6S color-key does not work well.
1,181件の閲覧回数
satoshishimoda
Senior Contributor I
Hi community,
I have a question about i.MX6SDL color-key.
Please see the attached file.
We are using MXCFB_SET_CLR_KEY to define color-key, but we can see the color which is specified to color-key after overlay.
Any idea to avoid this issue?
Satoshi Shimoda
ラベル(3)
1,056件の閲覧回数
Bio_TICFSL
Hi Satoshi,
Can you check the alpha values to make sure that they are set as you wish?, when the local alpha buffer set to full opacity (0xFF) you can get color-key values  to be transparent without affecting other display elements.
/Alfredo
