Hi all
Do you know what will be the difference in perfomance between DRR3 and LPDDR2 for iMX6 QuadPlus?
Or maybe do you know about some Android device with iMX6QP and LPDDR2 which can be used for tests and compared to SABRE AI?
Andy
Solved! Go to Solution.
Q. Do you know what will be the difference in perfomance between DRR3 and LPDDR2 for iMX6 QuadPlus?
A. Typically, for i.MX6 series processors, the data throughput performance of the DDR3 and LPDDR2 memories is similar when operating on the same type of processor with equal data bus width and bus frequency.
Q. Or maybe do you know about some Android device with iMX6QP and LPDDR2 which can be used for tests and compared to SABRE AI?
A. No, there is no ready to use i.MX6QP + LPDDR2 device available yet.
Artur
Thanks for reply!
Andy
Artur
