i.MX6Q - yocto alsa-utils only installs alsamixer and alsactl. How to install the rest?
abhayghatpande
I would like to install all the packages under alsa-utils like aplay, amixer, etc, but only alsamixer and alsactl get installed.
Do I have to include each one separate like alsa-utils-aplay, alsa-utils-amixer, etc.?
[It's strange because the .bb file for alsa-utils seems to have the rules for  all the packages.
My local.conf:
IMAGE_INSTALL_APPEND += " imx-vpu \
        alsa-lib alsa-tools alsa-state \
        alsa-utils fsl-alsa-plugins \
bblayers.conf:
BBLAYERS = " \
  ${BSPDIR}/sources/poky/meta \
  ${BSPDIR}/sources/poky/meta-yocto \
  ${BSPDIR}/sources/meta-openembedded/meta-oe \
  ${BSPDIR}/sources/meta-openembedded/meta-multimedia \
  ${BSPDIR}/sources/meta-openembedded/meta-gnome \
  ${BSPDIR}/sources/meta-openembedded/meta-ruby \
  ${BSPDIR}/sources/meta-fsl-arm \
  ${BSPDIR}/sources/meta-fsl-arm-extra \
  ${BSPDIR}/sources/meta-fsl-demos \
Labels (4)
abhayghatpande
When I added alsa-utils to CORE_IMAGE_EXTRA_INSTALL, all the packages were installed as expected. Not sure why IMAGE_INSTALL_APPEND does not work.
I was building the fsl-image-multimedia-full image.
