Hi community,
I meet a strange issue about sata mounting.
1) I modified init.rc like below ( add line in blue)
mkdir /mnt/extsd 0000 system system
symlink /mnt/extsd /extsd
mkdir /mnt/udisk 0000 system system
symlink /mnt/udisk /udisk
# jianhua@20140808 for sata/ssd
mkdir /mnt/ssd 0775 system system
symlink /mnt/ssd /ssd
2) I modified fstab.freescale like below (add line in blue)
/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc2 /mnt/extsd vfat defaults voldmanaged=sdcard:auto
/devices/platform/fsl-ehci /mnt/udisk vfat defaults voldmanaged=sdcard:auto
/devices/platform/ahci /mnt/ssd ntfs defaults voldmanaged=ssd:auto
after system bootup, there are none file lists in /ssd folder
However, if I changed fstab.freescale like below:
/devices/platform/ahci /mnt/extsd ntfs defaults voldmanaged=ssd:auto
after system bootup, there are correct file list in /extsd folder that are just the files in sata disk.
could you give me some advices why such difference. ( finally, i want to mount sata disk in ssd folder, because extsd should be reserved for external sd card).
Many thx...
Dear Jianhua,
May I get that fstab for SATA device ? because right now, I'm trying to mount the filesystem through SATA device.
Thank You.
J.P.Raja
Hello Jianhua,
Correct, If you want to use SATA disk in android system, you should mount it as an "extsd" in fstab.
Weidong
