[i.MX6Q] playback not smooth! (H.264 480 30p)
1,325 次查看
castel
     We're stuck in a playback issue, some jitter or freeze occur when we play 1~2 video (h.264,480 30p, I-frame only).
     but it's OK to play other 4~6 videos simultaneously, composed of I/P/B-frame in the same resolution, framerate & codec as above.
     is it normal at i.MX6? or it could be solved by F/W patch?
thanks.
标签 (2)
1,202 次查看
daiane_angolini
I'm sorry, I did not understand what you'd asked.
Could you, please, look at Release Notes from your release if the feature you're testing is supported? (I mean, it looks like you're trying some h264 parameter)
If it's supported or you do not find any reference, please, share some log or your command line.
1,202 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
No more comments from customer.
