I'm having difficulty understanding how to enable power using the USB_H1_PWR in ALT6.
Here's the u-boot setup for our custom board.
iomux_v3_cfg_t const usb_hc1_pads[] = {
MX6_PAD_EIM_D31__USB_H1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
MX6_PAD_EIM_D30__USB_H1_OC | MUX_PAD_CTRL(NO_PAD_CTRL),
imx_iomux_v3_setup_multiple_pads(usb_hc1_pads,ARRAY_SIZE(usb_hc1_pads));
u-boot has the following line to enable power using gpio for standard configuration....
---> gpio_direction_output(IMX_GPIO_NR(1, 29), 1);
Question is; how do I enable the USB power for ALT6 mode?
