Does anyone know if the FlexCAN driver in the linux bsp has the workaround implemented as described in ERR05829? The note says that there is no software workaround available, but a workaround is presented in the document.
Wayne
Solved! Go to Solution.
Hello Wayne,
No, it is not implemented. You need to implement it until the fix is available. The instructions on the workaround are in the errata.
Hello Wayne,
