Hi community,
I have a question about i.MX6DQ ERR005768.
I want to know the relationship between boot device and ERR005768.
I believe ERR005768 can occur when use NAND as boot device since secondary image is prepared generally when NAND is used.
How about other boot device?
ERR005768 can occur with other boot device? (e.g. eMMC, Parallel NOR, etc...)
Satoshi Shimoda
Solved! Go to Solution.
The ERR005768 silicon erratum is applicable to all boot modes that support redundant boot. These modes are:
-NAND Flash boot;
-SD/MMC/eMMC boot;
-SATA boot.
Artur
-NAND Flash boot;
-SD/MMC/eMMC boot;
-SATA boot.
Artur
