We are developing a device that supports the i.MX6DL and i.MX6DP processors. Is there a separate device tree for the DP processor? If so, what is it called?
Hi Paul
I am afraid there is no separate device tree for the DP, and QP dts may be used:
arch/arm/boot/dts/imx6qp-sabresd.dts
linux-imx.git - i.MX Linux Kernel
As example of D device tree one can check SCM-i.MX6D: Single Chip Module-i.MX6D (compare it with
corresponding SCM-i.MX6Q)
https://www.nxp.com/products/single-chip-modules/single-chip-module-i.mx-6d:SCM-i.MX6D?tab=Design_To...
