env:
gstreamer-1.8.1
imx-gst1.0-plugin-4.1.1
qt-gstreamer
when playing two pipelines one time,
ex: v4l2src device=/dev/video0 ! imxvideoconvert_g2d ratiton=0 ! qwidget5videosink
v4l2src device=/dev/video1 ! imxvideoconvert_g2d ratiton=1 ! qwidget5videosink
two qt widget window
sometimes got errors: g2d_cache_op: fail with status -7g2d_cache_op: fail with status -7g2d_cache_op: fail with status -7g2d_open: fail with status -7
only one window has video.
how can i fix this ?
can you tell me how to install gstreamer in linux not through ubuntu
i want to uses the waf meta build system build my cross compilation ,But now I don't know how to change the environment variable, or how to compile and port the entire program to imx6.q,As you said, can yocto support gstreamer-imx?Thank you for your reply
