i.MX6DL two pipelines playing for imxvideoconvert_g2d issue
1,745 次查看
ganhongxing
env:
gstreamer-1.8.1
imx-gst1.0-plugin-4.1.1
qt-gstreamer
when playing two pipelines one time,
ex:  v4l2src device=/dev/video0 ! imxvideoconvert_g2d ratiton=0 !  qwidget5videosink
      v4l2src device=/dev/video1 ! imxvideoconvert_g2d ratiton=1 !  qwidget5videosink
two qt widget window
sometimes got errors: g2d_cache_op: fail with status -7g2d_cache_op: fail with status -7g2d_cache_op: fail with status -7g2d_open: fail with status -7
only one window has video.
how can i fix this ?
标签 (3)
4 回复数
1,519 次查看
1130692457
can you tell me how to install gstreamer in linux not through ubuntu
1,519 次查看
joanxie
did you install any nxp bsp? like yocto? if yes, the bsp includes gstreamer already. what OS do you want to use?
1,519 次查看
1130692457
i want to uses the waf meta build system build my cross compilation ,But now I don't know how to change the environment variable, or how to compile and port the entire program to imx6.q,As you said, can yocto support gstreamer-imx?Thank you for your reply
1,519 次查看
joanxie
did you play video to different outputu or  to the main window?
is this random error? how long will you get this error when you play the video?
