i.MX6DL Dual Lite 2G version GPU hang issue in Yocto 4.2 with kernel version 6.1.22.
charleshuang
Senior Contributor II
Hi NXP
The log message.
The imx6dl dts file and our dtsi.
https://github.com/ADVANTECH-Corp/linux-imx/blob/adv_6.1.22_2.0.0/arch/arm/boot/dts/imx6dl-rsb4411-a...
https://github.com/ADVANTECH-Corp/linux-imx/blob/adv_6.1.22_2.0.0/arch/arm/boot/dts/imx6qdl-advantec...
Do you have any advice?
Labels (2)
Chavira
Chavira
HI @charleshuang!
What board are you using?
That links are not the official nxp repo.
If you have a development board from a partner you should contacting support in the company that is modifiying our software to their boards.
Best Regards!
Chavira
charleshuang
Hi Chavira,
Since we don't have the i.MX6DL demo board, we are using the Advantech RSB-4411 i.MX6DL 2G board, which does not have the PMIC used on the NXP demo board.
Do you have the i.MX6DL demo board? Can you test it on Yocto 4.2?
Thanks.
Chavira
Hi @charleshuang!
Yes we have a demo board from NXP but doesn´t have problems reported.
please contact to Advantech Support .
Best Regards!
Chavira
charleshuang
Hi @Chavira
I am the sw engineer from Advantech.
If possible, please provide the startup log messages for the Yocto 4.2 version running on an imx6dl demo board.
Thanks about your help.
Chavira
HI @charleshuang!
I don´t have that demo board at the moment I only have the iMX6Q.
I think that you have some miss configuration in the ram.
Are you doing the proper changes for your board?
I know that you have the same board running with other RAM sizes and the RAM files and configurations should be updated too according with our porting guide.
https://www.nxp.com/docs/en/user-guide/IMX_PORTING_GUIDE.pdf
Best Regards!
Chavira
charleshuang
Hi @Chavira
We have not missed any configuration in the RAM (U-Boot) because we are using the same U-Boot, which includes the DDR RAM parameters.
Do you have any advice in Kernel setting?
Thanks.
Chavira
Hi @charleshuang!
I am not sure what could be wrong with your board.
Can You compare the device tree with our sabre board:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm/boot/dts/imx6qdl-sabreauto.dtsi
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/arch/arm/boot/dts/imx6dl-sabreauto.dts
Best regards!
Chavira
charleshuang
Hi NXP and @Chavira
We already fixed the issue.
Thanks for your help.
