I am trying to read the EDID of the monitor connected to HDMI port.
This command probably gives me the EDID content after initialization:
$cat /sys/devices/platform/mxc_hdmi/edid
I would like to issue an i2c edid read command in user space.
Is there any sample code showing how to do this?
malikcis
Solved! Go to Solution.
Hi malik
one can try monitor-edid
bash - How to check if EDID can be tusted - Unix & Linux Stack Exchange
or look through /sys nodes
xrandr - How to get EDID for a single monitor? - Unix & Linux Stack Exchange
Hi malik
Thank you Igor for these useful hints.
