i.MX6 xml file in IOMUX tool.
1,214 次查看
satoshishimoda
Senior Contributor I
Hi community,
I have a question about i.MX6 IOMUX Tool.
I checked IOMUX setting in i.MX6DQ_Smart_Device.RevB.IoMuxDesign.xml in IOMUX tool (Rev. 3.4.0.3) and MCIMX6Q_SDP (Rev.C5), and I found some differences.
The following pads are example that there is difference between the xml file and rev.C5 board.
Pad Name:     IOMUX Tool,     Rev.C5 board
GPIO_1:     GPIO1_IO01(ALT5),      WDOG_B(ALT1)
KEY_ROW2:     GPIO4_IO11(ALT5),     HDMI_CEC_IN(ALT6)
EIM_DA6:     GPIO3_IO06(ALT5),     EPDC_SDCE2(ALT9)
So would you send us the latest xml file corresponded to the latest evaluation board?
Satoshi Shimoda
标签 (4)
标记 (2)
1 回复
913 次查看
gusarambula
Hello Satoshi Shimoda,
Unfortunately I wasn’t able to locate the Rev. C5 file. Either way I would not recommend using any board .xml as is without double checking that it matches your desired design.
