i.MX6 sysfs GPIO value report error on MCIMX6Q-SDP with yocto 3.14.28
1,234 次查看
m_c
Senior Contributor I
We use below command to test and found error.
memtool IOMUXC.SW_MUX_CTL_PAD_ENET_TXD0.MUX_MODE
cd /sys/class/gpio
echo 30 > export
cd gpio30
echo out > direction
cat value
memtool GPIO1.DR
echo 1 > value
cat value
cat value
cat value
memtool GPIO1.DR
memtool IOMUXC.SW_MUX_CTL_PAD_EIM_EB2.MUX_MODE
cd /sys/class/gpio
echo 62 > export
cd gpio62
cat value
memtool GPIO2.DR
echo 1 > value
cat value
cat value
cat value
memtool GPIO2.DR
Test result
root@imx6qsabresd:~# memtool IOMUXC.SW_MUX_CTL_PAD_ENET_TXD0.MUX_MODE
SOC: i.MX6Q
IOMUXC   Addr:0x20e0000
  IOMUXC.SW_MUX_CTL_PAD_ENET_TXD0 Addr:0x020E01F0 Value:0x00000005 -
     IOMUXC.SW_MUX_CTL_PAD_ENET_TXD0.MUX_MODE(0..2)     :0x5
             MUX Mode Select Field.
root@imx6qsabresd:~# cd /sys/class/gpio
root@imx6qsabresd:/sys/class/gpio# echo 30 > export
root@imx6qsabresd:/sys/class/gpio# cd gpio30
root@imx6qsabresd:/sys/class/gpio/gpio30# echo out > direction
root@imx6qsabresd:/sys/class/gpio/gpio30# cat value
!!!!!! drivers/gpio/gpio-generic.c:143:bgpio_get() gpio=30
!!!!!! drivers/gpio/gpio-generic.c:144:bgpio_get() bgc->reg_dat=0xc0820008
!!!!!! drivers/gpio/gpio-generic.c:145:bgpio_get() bgc->read_reg()=0x1c1f03f8
!!!!!! drivers/gpio/gpio-generic.c:146:bgpio_get() bgc->pin2mask()=0x40000000
0
root@imx6qsabresd:/sys/class/gpio/gpio30# memtool GPIO1.DR
SOC: i.MX6Q
GPIO1    Addr:0x209c000
  GPIO1.DR Addr:0x0209C000 Value:0x3E1F03F8 - The 32-bit GPIO_DR register stores data that is ready to be driven to the output lines.
     GPIO1.DR.DR(0..31)         :0x3e1f03f8
             Data bits.
root@imx6qsabresd:/sys/class/gpio/gpio30# echo 1 > value
0
0
0
SOC: i.MX6Q
  GPIO1.DR Addr:0x0209C000 Value:0x7E1F03F8 - The 32-bit GPIO_DR register stores data that is ready to be driven to the output lines.
     GPIO1.DR.DR(0..31)         :0x7e1f03f8
             Data bits.
root@imx6qsabresd:~# memtool IOMUXC.SW_MUX_CTL_PAD_EIM_EB2.MUX_MODE
PIO2.DR
SOC: i.MX6Q
  IOMUXC.SW_MUX_CTL_PAD_EIM_EB2 Addr:0x020E008C Value:0x00000005 -
     IOMUXC.SW_MUX_CTL_PAD_EIM_EB2.MUX_MODE(0..2)       :0x5
root@imx6qsabresd:/sys/class/gpio# echo 62 > export
root@imx6qsabresd:/sys/class/gpio# cd gpio62
root@imx6qsabresd:/sys/class/gpio/gpio62# echo out > direction
root@imx6qsabresd:/sys/class/gpio/gpio62# cat value
!!!!!! drivers/gpio/gpio-generic.c:144:bgpio_get() bgc->reg_dat=0xc0828008
!!!!!! drivers/gpio/gpio-generic.c:145:bgpio_get() bgc->read_reg()=0x0100000c
0
root@imx6qsabresd:/sys/class/gpio/gpio62# memtool GPIO2.DR
SOC: i.MX6Q
GPIO2    Addr:0x20a0000
  GPIO2.DR Addr:0x020A0000 Value:0x8100000C - The 32-bit GPIO_DR register stores data that is ready to be driven to the output lines.
     GPIO2.DR.DR(0..31)         :0x8100000c
             Data bits.
root@imx6qsabresd:/sys/class/gpio/gpio62# echo 1 > value
0
0
0
SOC: i.MX6Q
  GPIO2.DR Addr:0x020A0000 Value:0xC100000C - The 32-bit GPIO_DR register stores data that is ready to be driven to the output lines.
     GPIO2.DR.DR(0..31)         :0xc100000c
             Data bits.
Original Attachment has been moved to: 20160407-mcimx6qsdp-debug_gpio-10.txt.zip
Original Attachment has been moved to: L3.14.28-debug-gpio.diff.zip
标签 (3)
标记 (2)
0 回复数
