i.MX6 linux-imx spi-nor driver
宗標廖
Contributor V
Hello,community
I am now working with L3.10.17 on Freescale i.MX6soloSabreauto board(which with nor-flash m25p32 equipped).
When I run mxc_spi_test under unit_test folder,I always got Error:cannot open device (Maybe not present in your board?).
I know reason for this error is that the kernel has not create /dev/spidevB.C(B for bus num, C for chip select) node.
I read the device tree files and other related files,but I have not found any solution.
And then I tested with L3.0.35,the result is the same with L3.10.17.
Could you let me know why the kernel donnot create device node for spi-nor? And where to modify to reslove this problem.
Thank you!
ZongbiaoLiao
Labels (3)
Tags (3)
Hi 宗標
please check link below, verify changing driver name to spidev
and option "CONFIG_SPI_SPIDEV=y" in your kernel
Re: How to enable spidev for all SPI (1-5) for MX6
