I'm thinking of trying to create a dual monitor of EPD in i.MX6 dual lite. (EPDx2)
Split display the "two-screen" that was created in the app.
I think that trying to achieve by using the dual scan of EPDC.
However, since in this case one screen divided into two parts,
The output from the EPDC in the two cables I think that trying to output to the EPD.
Whether this method is possible?
Solved! Go to Solution.
Hi hiroyuki
I believe you are right, this could be feasible.
Hi hiroyuki
