i.MX6 boot appear "ECC error" information
1,383 次查看
jackjiang
Dear,
The following information appears at startup. How to solve it? Thanks.
标签 (1)
2 回复数
1,280 次查看
Hi Jack
seems image is corrupted, probably due to sudden powering off during nand operations.
One can try to reprogram image using mfg tool from link
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
1,280 次查看
jackjiang
Thanks igor,
You are right, the issue was solved after reprogram image using mfg tool, but this method is too troublesome, whether there are other solutions, such as operating through Uboot.
