i.MX6 boot appear "ECC error" information
Search instead for
jackjiang
Dear,
The following information appears at startup. How to solve it? Thanks.
igorpadykov
Hi Jack
seems image is corrupted, probably due to sudden powering off during nand operations.
One can try to reprogram image using mfg tool from link
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
jackjiang
Thanks igor,
You are right, the issue was solved after reprogram image using mfg tool, but this method is too troublesome, whether there are other solutions, such as operating through Uboot.
