Even though some overview documents mention, that the i.MX6 have VFP, the datasheet does not. Since this is an optional module, not mentioning it means "not included".
Therefore: can anybody of Freescale please confirm this and UPDATE the datasheet?
Thanks und regards,
-Rob
Solved! Go to Solution.
In section 12.4.2 “Media Processing Engine (MPE - NEON)” :
of the i.MX6Q Reference Manual (IMX6DQRM) :
“The MPE also implements a VFPv3-D32 Floating-Point Unit.”
Also the following provide some details :
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0409e/index.html
