I am trying to select a PMIC for i.mx6 ULL and ULZ based design. I cant find any compatible PMIC for ULZ at all.
Are pf1510, PF3000 compatible with both i.MX6 ULL and ULZ?Thanks in advance.
Hi @meafsin,
You can use the PF1550 or PF3001. Both are the PMIC compatible with the i.MX6ULL and the i.MX6ULZ, any you choose should work flawlessly.
Israel.
can PF3000 be used with ULL and ULZ as well?
Yes, it can be used.
Israel-
never-displayed
