i.MX6 SoloX Processor Top Marking
muneeswaran_r
Where I can find the Part marking details for following parts?
I am not able to find details in the datasheet.
MCIMX6X4CVM08AC
MMPF0200F6AEP
Thanks & Regards,
Muneeswaran R
muneeswaran_r
Ok Thanks Ruben for your support.
Muneeswaran R
muneeswaran_r
Hi Ruben,
Thanks for your reply.
I don't need decoding of part numbers.
I just need part marking details in the top of IC, this we need to verify IC during Visual inspection.
And also you shared link not showing any content for me.
Thanks for sharing details for MMPF0200F6AEP.
Can you please also share the details for MCIMX6X4CVM08AC ?
Muneeswaran R
nxf54947
Hi muneeswaran.r@vvdntech.in‌,
Thank you for letting me know that the previous link didn´t work upon. I was trying to point you out to the part number nomenclature (Figure 1) contained on the i.MX 6 Solo X's Datasheet:
www.nxp.com/docs/en/data-sheet/IMX6SXIEC.pdf#page=5
Unfortunately, I am not allowed to share more details on the MCIMX6X4CVM08AC's part marking on this community. For that end, my suggestion is to open a support ticket (if needed, you can find a guide of this process below):
https://community.nxp.com/docs/DOC-329745
My apologies for the inconvenience caused.
Ruben
nxf54947
Hello muneeswaran.r@vvdntech.in,
Are you trying to decode the part numbers of both parts?
I assume you were reviewing  MCIMX6X4CVM08AC - Figure 1. Part Number Nomenclature—i.MX 6SoloX, but I want to be sure that we are taking about the same topic.
Regarding the PMIC  MMPF0200F6AEP, please check figure below. Unfortunately, I am not able to share more details on the last row decoding.
Please take into account that this marking conventions are closed from public to avoid counterfeiting. However, you can obtain more information from your local marketing office.
I hope this information was useful.
Ruben
Edit: corrected the link provided
