Hi Scott
power-up sequence is decribed in sect.4.2.1 Power-Up Sequence
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SXCEC.pdf
Also one can use verified on Sabre board sequence with F0200F6 and
VDD_HIGH_IN powered before core voltages. VDD_HIGH powers control logic
of internal ldos, so powering it first allows for more smooth rising of other power
supplies. None programmed version PF0200NP can not be used as it is designed
for further programming for customer needs.
