i.MX6 SPDIF 96KHz playback support
Search instead for
saurabh206
Senior Contributor III
Hi Community,
BSP 3.14.28.
I am able to get 48KHz, playback using SPDIF out.
96KHz playback is not working. I have not seen any error in SPDIF register.
96KHz playback support is available? Or any modification is required?
Labels (2)
shanxigjz
Hi  Saurabh,
I am trying to imx6 spdif output to play audio files.
but i can not get it work.
When i play files, it blocked and never return back.
Could you tell me how you get your spdif output playback worked?
Thank you very much.
saurabh206
Hi Gao,
We are able to get 96KHz playback working.
Saurabh
igorpadykov
Hi Saurabh
seems s/pdif driver does not support it as described in attached Linux
Manual sect.31.1.3 Software Overview
saurabh206
Hi Igor
Thanks for your replay.
Is there any software limitation or hardware limitation?
However Manual mentioned that 96KHz capture support is available.
96KHz , 24 bit is now very generalized audio requirement.
Saurabh
igorpadykov
Hi Saurabh
this is driver limitation, not hardware
~igor
