i.MX6 Quadro (MCIMX6Q5EYM10AD) does not start from SD card
j-avdeev
Hello.
I have tried to start my i.MX6 Quadro with binaries flashed on SD card, but no luck.
I took images from here
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
BSP, Drivers and Middleware:
L4.14.78_1.0.0_ga_images_MX6QPDLSOLOX
L3.14.52_1.1.0_MX6QDLSOLO
but no luck.
Are the following images compatible with i.MX6 Quadro?
Thanks.
Bio_TICFSL
Hello j-adveev,
If you burn ok the sdcard the you need only to change the SW of your board, if you have the SABREboard then:
Switch conf for SD
S1 pin4=>0,pin5=>1
S2 pin2=>0,pin3=>1,pin4=>0
S3 pin1=>0,pin2=>0,pin3=>1,pin4=>0
