不能显示该小部件。
不能显示该小部件。
不能显示该小部件。
不能显示该小部件。
不能显示该小部件。
i.MX6 Plus - Stress Tool for Yocto1.8
1,050 次查看
yen-polin
Hi ,
Configuration : i.MX6 Plus + Yocto 1.8
I'll measure the CPU_TEMP. and Power_Consumption(Max) when i.MX6 full loading .
Does it have any command(including the parameter) or Burning_tool to verify the system's quality ?
Thanks a lot.
YenPo Lin
1 回复
907 次查看
Yuri
  Section 4.1.5 (Maximum Supply Currents) of the i.MX6 QP Datasheet
describes stress testing tools.
http://www.nxp.com/files/32bit/doc/data_sheet/IMX6DQPCEC.pdf?fasp=1&WT_TYPE=Data%20Sheets&WT_VENDOR=...
Yuri
