One of the booting methods supported by the MX6Q-SDB is to read U-Boot from a SDCARD, load the Linux kernel (uImage) from a TFTP server and NFS mount a root file system from a host. Please refer to Setting_Up_LTIB_Host.pdf in the Linux Bundle for i.MX 6Quad/Dual for host configuration steps.
U-Boot environment variables are used to provide the details of the boot mode. Here are definitions of variables to consider changing from the default values for your environment. NOTE for the definitive guide please see http://denx.de.
To set an environment variable use the setenv command. The syntax is setenv variableName value. ‘=‘ character is not valid for setenv.
Thus setenv variableName=value will be rejected.
To show variables use the printenv command.
U-Boot Variable | Description |
bootdelay | Count down in seconds before U-Boot begins boot process. To halt, strike any key and the U-Boot prompt is presented |
bootcmd | U-Boot executes this definition after the bootdelay |
serverip | IP address of the host. This provides the TFTP server and exports directory for NFS mounting. |
ipaddr | IP address of the target (MX6Q-SDB) |
bootcmd_net | Configuration used for network booting: setup bootargs, tftp read uImage Linux kernel from TFTP server host and store in DDR memory, jump to loaded Kernel and begin executing. |
bootargs_base | Clear the bootargs environment string and setup the console string: console=ttymxc0,115200 |
nfsroot | The NFS exported directory of the host specified by serverip. |
bootargs_nfs | This builds upon bootargs, adding to the console setup the NFS specifics: root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v2,tcp NOTE: the default setting has v3 which specifies NFS protocol version. Ubuntu 12.04.02 Precise was rejecting this setting, changing to v2 was successful. Please refer to the man page on nfs for additional details. |
bootargs | This variable is passed to the kernel. |
This discussion was based on Freescale BSP Linux release L3.0.35-4.0.0 for the MX6Q-SDB platform.
The working U-Boot environment for NFS Boot :
MX6Q SABRESD U-Boot > printenv
bootdelay=3
baudrate=115200
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=(0x1300000)
netdev=eth0
ethprime=FEC0
uboot=u-boot.bin
kernel=uImage
bootcmd_net=run bootargs_base bootargs_nfs; tftpboot ${loadaddr} ${kernel}; bootm
bootcmd=run bootcmd_net
ethact=FEC0
ipaddr=192.168.1.20
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v2,tcp
video=video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 ldb=sin1
serverip=192.168.1.100
nfsroot=/var/fs/mx6q/caam/rootfs
extra=caam
bootargs_base=setenv bootargs console=ttymxc0,115200 ${video} ${extra}
stdin=serial
stdout=serial
stderr=serial
Environment size: 792/8188 bytes
