Hi community,
Our partner have a question about i.MX6DQ IPU.
Please see chapter 38.4.9.5 in IMX6SDLRM Rev1.
They want to use the CSC for YUV420 -> RGB conversion.
However, we don't understand what value should we set to each paratmeter CSC_Ax, CSC_Bx, and CSC_Sx.
Do you have a sample setting for YUV420 -> RGB?
And if there is some restriction for using CSC, could you let me know it?
(e.g. color conversion is not work well if image resolution is not multiple of 16)
Satoshi Shimoda
Solved! Go to Solution.
Hi Satoshi
please look below
ipu-examples release notes - v0.1
Hi Satoshi
please look below
