[i.MX6] How could I know about i.MX6 output timing between CK and ADDR/CMD?
hiroakidoi
Hi everyone,
For DQ or DQS, I found out about Read calibration or Write calibration, but I couldn't see about CK and ADDR/CMD.
I need these parameters for SI Simulation.
Thanks in advance for any help!
Rita_Wang
What SI Simulation do you need to do , for DDR section we have configure script and stress test tool for it.
hiroakidoi
Hi Rita_Wang,
Thank you for Replying.
We have adapted the script to our design and have done stress checks.
However, as the number of prototypes increased, some prototypes did not boot Linux or hung during operation. In addition, the i.MX6 and DDR of those defective products were prone to defects when warmed up.
We are considering the possibility that the defects may be caused by PVT variations and would like to perform SI simulations to check for SI problems.
We have the IBIS model and board S-parameters already obtained, the rest we need is the timing parameters.
So please let me know the Output Timing Parameter of CK-ADDR/CMD.
Rita_Wang
If using LPDDR2, CA-Bus delay is showd in register WRCADL.
For DDR3 there is no register since no training for it in JEDEC.
The delay from CK to CA is controlled by routing rules. You could find it in HDG.
hiroakidoi
Hi Rita,
Thank you for replying.
I would like to continue communication with e-mails that you introduced.
Thank you.
hiroakidoi
Dear Rita,
I thought I sent you an e-mail yesterday.
but I am not sure if the way to send e-mail is to post in the comment box.
If it has been confirmed, could you please reply once?
hiroakidoi
Dear Rita,
I commented on the e-mail again as my question is still unanswered. Please check and reply.
Best,
Hiroaki
Rita_Wang
OK, I will check it. Sorry for missing it
hiroakidoi
Dear Rita,
I commented on the e-mail again. Please check and reply.
Best,
Hiroaki
hiroakidoi
As this file supplements our question, please confirm it.
