Hi community,
Our partner have a question about i.MX6SDL EIM.
Please see chapter 22.9.1 in IMC6SDLRM (Rev.1).
I want to know what is different between the following two cases.
[Case 1]
WC: 0 (Write access burst length occurs according to BL value)
BL: 100 (Continuous burst length)
SWR: 1 (write accesses are in Synchronous mode)
[Case 2]
WC: 1 (Write access burst length is continuous)
Would you let me know what is different and what defines the burst length in each case?
Satoshi Shimoda
Solved! Go to Solution.
Generally, there is no difference between these two cases.
Artur
Artur
Hi community,
Would you give me advice?
Satoshi Shimoda
