Does LVDS support JEIDA model for i.MX6?
If LVDS supports JEIDA mode for iMX6, can you tell me which reference panel you used?
Can you tell me how to change the JEIDA mode in the application level?
Thank you.
Alex
Hi charles
JEIDA is supported as mentioned in sect.39.5.2 Bit Mapping
i.MX6DQ Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
property "fsl,data-mapping" in dts file selects it
linux-2.6-imx.git - Freescale i.MX Linux Tree
Unfortunately I am not aware of tested panels.
