Hi Dmitry
you are correct:
from i.MX_6Dual6Quad_SABRE-SD_Linux_Release_Notes.pdf L3.0.35_4.1.0_LINUX_DOCS
Table 7. Known Issues and Workarounds
"Current SD board uses KEY relative PINs as
SPI interface. However, this set of PINs are not
supported by ROM.
Therefore, SPI NOR boot is not supported by Smart Device Board."
