i.MX53 user buttons trigger when touched and board ungrounded
1,180 次查看
SimonasL_
Dear all,
When I operate i.MX53 stand-alone -- only with LCD via touch-screen, have only power supply  connected and no other peripherals attached, -- boards suffers from poor grounding, by exposing hectic USER1+2 button activity:
Whenever I touch any of those buttons (no press-action involved), it starts sending pressed events at an extremely fast rate (potentially halting the running OS).
Whenever I attach a well-grounded cable (USB/µUSB, serial, VGA), this behaviour goes away.
The board is intended to be used as stand-alone, without any wires supplied and no possibility to ground it - how could the button behaviour be fixed? Soldering a capacitor did not help (it then nearly completely disabled buttons sending any action when pressed)
Many thanks,
Simonas
标记 (1)
1,064 次查看
Bhavana
Can you help me to make use of user1 and user2 keys ..so that if we press that keys some event should generated.
