i.MX53 QSB camera
Search instead for
i.MX53 QSB camera
dhlii
I need to connect an NTSC or PAL camera as input to an i.mx53 QSB.
It has been sugested that there are chips that might convert analog video to something matching the digital video inputs on the i.MX53. I am looking for sugestions if someone might have some.
AaronLinsdau
I've used the ADV7180 with good success on other projects.  Just make sure you follow the chip's layout suggestions exactly, otherwise you'll have noisy video.
LakshmiNarsimha
Please check this NTSC / PAL Video Decoder Board for i.MX53 Processors from e-con Systems.
