I have few QSB boards with several 10.1'' LVDS touch screen. Some of the LVDS cable that came with the screen when I purchased it are broken. I tried contacting Freescale (both directly and their re-seller), but the answer I got from both was that I need to find a replacement somewhere else.
Does anyone know where I can order to right cables ? Unfortunately, the cables has no part number or any other description.
Thanks in advance,
Chen
What you're looking for is a cable with DF19-30S connectors (Hirose) or similar.
I just ordered a bunch of these cables from a supplier in China. They are only 75mm long, but If that's no problem for you I can get you some (I had to order 100 pcs....)
Thanks for reply,
I need five of them.
Dig up their QSB data sheet, Freescale did post part numbers for their LVDS cable connectors
