Now we are debugging LPDDR2 timing for our custom i.MX53 board.
(Please see our previous thread : https://community.freescale.com/message/533008)
We tried to change ESDCTL_SDCTRL for adjust delay of SDCLK.
For the bit11-8 field description on p1298 of RM shows as following: "Add sdclk0 delay of 1 delay units."
(Q1) How many [pSec] does 1 delay units mean?
(Q2) Does more/bigger delay improve timing margin to the CS/RAS/CAS/WE/<adr>/<dat> of DDR2 read?
When we write 0x00000300(SDclk0_del=2'b11) to the ESDCTL_SDCTRL with JTAG-ICE, but read value was 0x00018000.
(Q3) What was wrong with my writing?
Best Regards.
Solved! Go to Solution.
Hi torus1000
1. 1 delay unit varies between 20 pSec in best case to 50 in worst case
2. yes
3. had you provided clocks to ESDCTL, is access provided as 32bit word ?
Please try to reproduce this on Freescale reference board, QuickStart board with
debugger tool which is used in Freescale - ARM RealView ICE. One can follow
Chapter 9 Configuring JTAG Tools for Debugging MX53UG
Hi torus1000
2. yes
