i.MX51 SDHC CMD0 Results In Cmd Line Conflict
hallet1
Working with i.MX51 SDHC and trying to issue CMD0.
Instead of resulting in CC bit set in Interrupt Status register
I keep getting CRC err and Timeout Interrupt Status bits set
which indicate Cmd Line Conflict.
I check CIHB and CDIHB before issuing CMD0 even though
only CIHB needs to be checked since CMD0 does not use the
data lines.
Anyone know how to resolve a cmd line conflict like this?
Thank you.
Tags (2)
admin
Specialist II
Hi hallet1,
Here's how MaxTsai responded to your question:
hi, I didn't get hallet1's point. Regarding to i.MX51/53 mmc host driver, there is a timer waiting for CIHB is clear.
"drivers/mmc/host/mx_sdhci.c"
static void sdhci_send_command(struct sdhci_host *host,
struct mmc_command *cmd)
     mask = SDHCI_CMD_INHIBIT;
     while (readl(host->ioaddr + SDHCI_PRESENT_STATE) & mask) {
             if (timeout == 0) {
                    printk(KERN_ERR "%s: Controller never released "
                            "inhibit bit(s).\n", mmc_hostname(host->mmc));
                     sdhci_dumpregs(host);
                    cmd->error = -EIO;
                    queue_work(host->workqueue, &host->finish_wq);
                    return;
          timeout--;
          udelay(20);
Max, if you have any questions for hallet1, feel free to ask him.
Grant
admin
Specialist II
Hi hallet1,
             if (timeout == 0) {
                    cmd->error = -EIO;
                    return;
          timeout--;
          udelay(20);
Grant
