i.MX28 on Ubuntu13.10 - L2.6.35_1.1.0_130130 patch failed error
arise
Hi All,
I am trying to setup the LTIB environament for i.MX28 on Ubuntu13.10 - 64bit OS. I am able to create the ~/ltib directory, later when I am trying to apply the patch to make L2.6.35_1.1.0_130130 getting below mentioned patch failed error.
Kindly any one please help me, in resolving the issue and proceed the rest of LTIB environment setup process.
HP-Compaq-6200-Pro-MT-PC:~/imx28/ltib$ git apply 0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch:113: space before tab in indent.
     keygen.o
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch:114: trailing whitespace.
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch:115: trailing whitespace.
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch:118: trailing whitespace.
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch:119: trailing whitespace.
error: patch failed: dist/lfs-5.1/base_libs/base_libs.spec:296
error: dist/lfs-5.1/base_libs/base_libs.spec: patch does not apply
error: patch failed: dist/lfs-5.1/elftosb/elftosb.spec:9
error: dist/lfs-5.1/elftosb/elftosb.spec: patch does not apply
error: patch failed: dist/lfs-5.1/lkc/lkc.spec:19
error: dist/lfs-5.1/lkc/lkc.spec: patch does not apply
error: patch failed: dist/lfs-5.1/mux_server/mux_server.spec:22
error: dist/lfs-5.1/mux_server/mux_server.spec: patch does not apply
error: patch failed: dist/lfs-5.1/ncurses/ncurses.spec:31
error: dist/lfs-5.1/ncurses/ncurses.spec: patch does not apply
error: pkgs/elftosb-2.6.35.3-1385779630.patch: already exists in working directory
error: pkgs/elftosb-2.6.35.3-1385779630.patch.md5: already exists in working directory
error: pkgs/lkc-1.4-lib.patch: already exists in working directory
error: pkgs/lkc-1.4-lib.patch.md5: already exists in working directory
schneider@schneider-HP-Compaq-6200-Pro-MT-PC:~/imx28/ltib$
Labels (2)
isaac_ng
In response to the original discussion about the issue to apply the $ git apply 0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch.
The patch is coming from this thread: Compile L2.6.35_1.1.0_130130 for i.MX28 on Ubuntu 13.10 64bit OS
It looks like the patch has been applied previously to the LTIB environment.  In the log, there are errors complaining the existence of these two files.
The above two files are coming from 0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch.
Thus, please only applied the patch once to a newly created L2.6.35_1.1.0_130130 LTIB environment for i.MX28.
chewhouming
My ubuntu version is 14.04, thus the patch above should be correct for installing linux target image builder.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.1 LTS
Release: 14.04
Codename: trusty
unziping and running git apply, mention the patch is not valid. I can't install ltib and thus not able to download linaro BSP onto my imx6. Please kindly assist.
git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:106: trailing whitespace.
%patch1 -p1
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:144: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:164: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:166: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:169: trailing whitespace.
alvin@ubuntu:~/ltib/ltib$ git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch
%patch1 -p1
isaac_ng
YixingKong
Senior Contributor IV
Arise
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Arise
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
YixingKong
Arise
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
